If I strip my kitchen out to a point where it is just a room. Then wire it. Then turn my room into a kitchen.... I'm technically not wiring a kitchen right?
*slap* take that part P
Do you mean that you'll add or change a cooker circuit?If I strip my kitchen out to a point where it is just a room. Then wire it. Then turn my room into a kitchen.... I'm technically not wiring a kitchen right?
4. For the purposes of this Schedule—You are definitely wiring a kitchen and you need to wire it as such.
You have to comply with Part P whichever room the work is in.Including Part P compliance and LABC notification.
4. For the purposes of this Schedule—You could say the same about a bathroom - wire it up how you like, then fit the plumbing and fixtures.
Probably not.Not a good idea.
So if it doesn't contain those it is not a kitchen.
And anyway - you can't wire things up how you like - it has to comply with the Building Regulations.
A little harsh I think.*slap* take that
I've got a way of you avoiding getting done for speeding too.I'm technically not wiring a kitchen right?
Ummm No they have definatly always been and always will be pants.A little harsh I think.*slap* take that
Some of their songs since they were resurrected have been quite good.
I'll think you'll find it is. The op said so himself.
OK - sorry - to me this:And anyway - you can't wire things up how you like - it has to comply with the Building Regulations.
That was my point...
read as if you were conflating Part P compliance and notification.You are definitely wiring a kitchen and you need to wire it as such. Including Part P compliance and LABC notification. You could say the same about a bathroom - wire it up how you like, then fit the plumbing and fixtures. Not a good idea.
Which means what?BAS,
The op has clearly stated that he will be turning the room back into a kitchen, which means he will be wiring it as such.
