(Ignoring the whole notifiable bit) unless it's a really short run to the shed you might want to upgrade from 4mm to 6mm or even 10mm SWA (for when you get a MIG welder or a hot tub).
Notifiable bit- very semantics. The run from house to shed you could argue is not a new circuit- it is refurbishment/upgrade of an existing circuit. Fitting a new garage CU on the end of it- again you could claim that this is not notifiable (a replacement CU on the other hand is). Some might say you are nit-picking, I would say that some highly-paid people drafted that document, if they intended that the fitting of a CU should always be notifiable then they would have left the word 'replacement' out of the documents. This is the sort of nit-picking that protects high net worth individuals from paying the levels of income tax that us mere mortals have to suffer....but I digress. At the end of the day, if you install competently, test and complete MWC then you've observed the spirit of the legislation. Building Control will charge you £350 for a certificate to achieve the letter but I'll leave that up to you
