All you guys must be psychic to be able to state that this patio is PD.
From one of your neighbours.The council has received a complaint in regards to the above
When they went to the neighbour's house.Following an investigation (??????? When did this happen
They can look over the fence.do I not get to show them in person?)
I would worry that submitting a planning application would be an admission that you think you need permission.It goes on to invite a retrospective planning application which isn't guaranteed to succeed
What can I do ?
Have you written to them pointing out that you have not gone more than 300mm AGL at the house?
If you say so, I'm merely stating that no other postes can tell from the photos.All you guys must be psychic to be able to state that this patio is PD.
Fair point but if I haven't fallen foul of the 300mm rule , what is there I could have done wrong and not under PD?
Because you cannot tell from the photos if it complies or not.
Ah - see what you mean.I would not consider the whole area you have paved to be one continuous deck and so the highest ground level for each deck must be used as a high point. It is a series of 4 different raised decks and each one must be compliant and I cannot tell from the photos if it complies or not.
