S
SaladFingers
But your signature says that low voltage is 230V.I'm not wrong, 240v IS low voltage.
So 240V is 230V then?
I knew you'd pick up on that one, dear.
240 volts, 230 volts, 220 volts, all low, my dearest bas x
Yes.I knew you'd pick up on that one, dear.
But are you pretending that there is no difference because you're a pathetic wriggler, or can you really not see the difference because you are stupid?
Which would you rather?
Would you prefer people to think that you are careless, lazy and pathetic, or that you are genuinely so thick that you can see no difference between "What is a Boeing 747? It is an aeroplane" and "What is an aeroplane? It is a Boeing 747"?
Pedants corner
Pedants corner
Pedants' corner, FFS.
I rather think I'm with BAS on this one.
If you're going to the bother of having a forum signature (and there's another argument right there), at least do your dignity and self-respect the honour of making sure it is accurate.
Do you still think that if you keep on pretending that there is no difference then somehow there really won't be one?
Or are you genuinely so thick that you really cannot see the difference?
Bertie asks, pointing to the shiney bladed wooden handled instrument, 'What's a screw driver?, One of those?'
You take the lead, we might respond.Pedantry can go for as many pages as you wish.
Q.E.D.Bertie asks, pointing to the shiney bladed wooden handled instrument, 'What's a screw driver?, One of those?'
'No no no' exclaims Rupert, 'one of those is a screw driver, but a screw driver isn't one of those, because there are many that are screw drivers
No it isn't. "Accurate" is the last thing that it is.This is the point I've been making, that in my meaning and reason for saying so, it is accurate.
Like I said - accusations of pedantry are being levelled here by someone who is wrong and is becoming more pathetically inadequate and laughably desperate every time he tries to make out he's not actually wrong, just a victim of pedantry.My darling Bas, I've already acknowledged the difference from word order many times over. You're continuing to unneseccarily say that I'm wrong and I'm continuing to say that from my order meaning, you're being pedantic.
It's not pedantry. You are thick.Sugar plum, we know what it all means, but you're simply being a pedant over this and will not let it go when to be honest, no one really cares that much, even if they do agree with your pedantry.
No - the analogy with what you are saying would be to claim that because that shiny bladed wooden handled instrument is a screwdriver then a screwdriver is a shiny bladed wooden handled instrument. Which would mean that an instrument with a dull blade or a non-wooden handle cannot be a screwdriver.Bertie asks, pointing to the shiney bladed wooden handled instrument, 'What's a screw driver?, One of those?'
'No no no' exclaims Rupert, 'one of those is a screw driver, but a screw driver isn't one of those, because there are many that are screw drivers.
The fact that 230V is low voltage does not mean that you can change the order of the words and say that low voltage is 230V.
You must be mentally deficient if you think that.
You seem to think that changing the order of the words does not make a statement incorrect.
Tell us all - do you really believe that if a regulation says that only buses, taxis and cycles may use bus-lanes that it also means, and therefore it would be correct to say, that buses, taxis and cycles may only use bus-lanes?
Are you prepared to answer that?
If you say that "low voltage is 230V" then you are making a definition, and therefore saying that nothing other than 230V is low voltage.
