Hi All,
I am having serious issues with this boiler, the hot water to the upstairs taps is working fine, except to the shower mixer which is just a manual type, the flexi pipe to the shower head needs to be replaced to stop the water flow being restricted.
The closest hot water to the boiler in the kitchen does not activate the microswitch on the boiler to fire it up.
I have cleaned out the cold water inlet filter on the boiler and replaced the diaphragm in the diverter valve, but still no activation of the microswitch when using this closest tap! there is 6ltrs per minute flow at the tap!
IDEAS PLS!!!
IDEAS PLS!!!
