periodic codes
Code 3 is basically for things outside the scope of the PIR hence I wouldn't use a code 3 for this.
Maybe code 2 if there was signs of heat damage or not installed to manufacturers instruction.
A code 3 is reserved for further investigation required, not necessarily outside the scope of a PIR, an example being unable to trace a final circuit.
im just wanting to know a thew codes that im unsure of
You asked about PIR codes 6 months ago
hello there, on a periodic test if the lighting circuit was not rcd protected would that be a code 2 or 4 thanks
What experience of inspection and testing do you have?
What qualifications do you have?
alright all, ive not long had my niceic domestic installer
Do NICEIC let you do PIRs?
[CLARIFICATION EDIT] Do NICEIC let you issue PIRs on red or purple forms? [/CLARIFICATION EDIT]
Umm....
alright all, ive not long had my niceic domestic installer, what do i need to get on the approved scheme? thanks
...you cant use just domestic can you, dose it have to be commercial industrial ect
basically ive only realy ever done domestic work, ive done bits of commercial, so thats why im asking would i have to do anything else other than domestic?
dont really do domestic work
The NIC cannot forbid any competent person from undertaking Periodic Inspection and Testing except on their own forms.
