Not all supernova become black holes though sooey. Some become neutron stars.That's right, (except for the supernova bit), for a star to collapse into a black hole it has to be 2 or 3 times bigger than our sun.
A little indian fella called Chandrasakar worked out exactly how massive they have to be on a boat to England, so it's called the Chandrasakar limit. Anything smaller doesn't have enough gravity to form a black hole.
I did say Supernova, not Black Hole.
I do not know if your question is realting to my original question Joe? Is it?
If both the Sun and Earth were to go instantly, then my understanding of what ths scientist bods think, there will be ripples from both the areas where the Sun and the Earth were, which would eventually smooth out to nothingness, no gravity pulling either way. To use the rubber sheet example that is popular when discussiong gravity fields, remove the weights and the rubber sheet would bounce up and down until the sheet comes to a standstill.
Does not answer the original question though.
Space isn't a rubber sheet though is it? But the analogy is good. Gravity is the product of the distortion of space by mass. Take away the mass and you take away gravity. Gedditt yet? Take away the sun and you take away the distortion of space - hence no gravity. Use your noodle - not google.
In that case , Brighton would be go before us , on the Forest . Well it`s always had a floating population anywaygone poof, , how soon after the Sun has disappeared would the lack of the Suns gravitational pull take effect?
Wasn`t he a slum landlord Riemann , not Joe 90 - tho` there may be some similarities, start thinking Riemannian mate.
Use your intellect. I am right. It could never happen in the real universe because matter/mass cannot just disappear. Therefore there is no 'real' answer to the question. Gravity may travel at the speed of light in the normal universe, but according to the question (which isn't possible) it doesn't apply. Find me a link that answers your question - not talking about gravity generally.
I maintain that:
The mass of the sun distorts space and gravity is the by-product.
Remove that mass instantly and you will remove gravity associated with that mass instantly.
Now use your noodle - not google.
I maintain that:
And no, I don't google stuff like you do - I use my own brain power.
