Hello there. Firstly a big thanks for all my previous questions.
I have an extension which I need to fit with radiators. The CH pipes will need to cross nearly every single joist in the new build.
I was wondering what the best practice was for pipes through joists. Should I drill with a hole cutter or should i notch out?
I would prefer to run 22mm pipe so i suppose this will make the hole bigger. Also since i need flow and return is it worth spacing out the holes / notches.
I suppose there is not much in it, but with such nice new joists i want to make minimal impact on the structure.
Many thanks.
Many thanks.
