Don't have the regs to hand but will have a peep later.
How about emergency lighing with incorrect legends?
Which is the reg which says that the PEBs when connecting say the water and gas must remain unbroken? I know this is one which we look for and record if they are broken, but not 100% sure on the reg no.
On another note I think I am about to have strong words with an NICEIC firm who has installed unsheathed cables in a wall but not in conduit/trunking etc.
Immersion heater without a safety cutout?
554.2.1?
A fuseboard containing asbestos flash pads?
132.1/511.1?
Dingbat, what kinds of frivolous observations were you seeing?
The 4 O's&R's were:
1: Bond gas meter - 2
2: Bond gas boiler pipes - 2 (sic)
3: Remove redundant off peak CU and wiring - 2 (sic)
4: Replace existing wylex 6 way fusebox with a crabtree RCD/MCB controlled c/unit - 2
Don't see the problem as long as every cable is rated correctly.Change in cable type eg swa joined to an micc.
