PIR light
5 Jul 2016
I've just changed a outdoor light to a PIR motion sensor sensor fitting, it is also connected to a day/night photocell when I turned the power back on nothing happened, I tried disconnecting the separate photocell but still nothing happened and since changing the fitting the light above the garage that I haven't touched didn't come on when I turned the power back on
please post photos of all the connections.
Can you borrow a multimeter?
Try to follow the cable route, especially from the garage light to the supply. Is there one of these?
It contains a fuse that might have blown if you made a mistake
It's fed straight fromeo distribution board there's seems to a supply cable to the photocell and a supply cable to the light a cable from the photocell is then connected to the light along with the light supply. the new light has no earth connector so that is just in a terminal block
I wired it exactly as it was cant get lives and neutrals mixed up I'll remove the photocell from the circuit and see if that works
