This forum was too entertaining, I had to join to seek advice and add if possible. I understand that this discussion is historic, but, people may learn something from reading old and new posts even if the original start of the thread is out of date.
Having worked out my ceiling plan, it looks as though 2.4 x 1.2 is the most efficient way of boarding out my ceiling. I'm using 9.5mm. I am hoping not to skim and use tapered edge board, tape the edges and fill with joint filler. Where two edges meet which aren't tapered I will use a generous bead of gripfill which I hope will prevent cracking
I'd like to use the so called 6x4 but can't seem to find it with tapered edges. It would be easier as I'm doing it on my own, but whats wrong with using a 'deadman'? - a piece of 2x1 with a plate on the end the height of the ceiling - jam it in under the board to help hold it place while you get a screw or two. I don't need to insulate as its ground floor and the ceiling is concrete. Its all being attached to batons.
If anyone has some helpful suggestions please add.
