12.5 + 25 = 37.5 so even if you use the shortest screws under the 3x rule (38mm) you will snub the point; that’s assuming your 25mm battens are actually 25mm. Screws at 400mm pitch is way too much for 12.5mm boards, on what bassis did decide that even 300mm pitch was overkill let alone 400mm; your boards will eventually bow & run a serious risk of failure in the long term.
I’ve got a strange feeling about where this thread is going, I suppose now you’re going to tell me you’ve calculated it! I never have but British Gypsum almost certainly have; I would be very interested in seeing your calculations &, yes, I would understand them. You ask advice & then start going all strange; your not geraint’s alter ego are you with the crap he’s coming out with at Alistair? Is there some trolling going on here? Bit tired of this sort of stuff, it's really a waste of my time; my last words are get on with it but buy yourself a hard hat.
