I always though the plastic bit enabled a snapped cord to be replaced without having to get into the switch.
Actually I recall that pull switches used to be a chain that forever broke and needed replacing before the string took over and at the time it was a smooth natural fibre like cotton which was equally vulnerable to breakage.
I’ve stopped watching this guys videos. He gets me too wound up. He presents himself as the best and most knowledgeable sparks in the world, yet does average quality installs, and gets things wrong time and time again.
Yes, or just easily replaced when it becomes dirty.I always though the plastic bit enabled a snapped cord to be replaced without having to get into the switch.
That's the stuff, and they would open up and fail, especially where it entered the housing.I think I half remember them or part of them being made from those chromed metal beads, sometimes seen linking bath plug to the bath overflow.
Deffo an electrical insulator.
Loads of steam makes the string wet and gets into the switch.
They didn't used to be fitted and shock reports used to occur.
Totally pukka.
Yep on the original [pre 1998 when I purchased the flat] and the replacement 3 years ago.Ever seen a plastic bit on the pull cord of a wall mounted bathroom fan heater?.
As you will have seen in post #14, I've been having the same problem but, like you, I am still not sure of the answerI am still not sure if you are being humourous...,
Who are you referring to?I am still not sure if you are being humourous - but if not, then:
If, as you seem to think, the cord is an exposed-conductive-part then it should be earthed.
Might you suggest how this could be achieved?
Perhaps another piece of string connecting the cord and the earth terminal?
Who knows - but of very limited value if one of the 'functionalities' is both silly and unnecessary!God forbid that this little piece of plastic can have dual functionality....
