Transposing one set of disadvantages for another without explaining.
but how many of us with an experience greater than 1 poxy cottage
Very nice, now that you've inflated your ego a bit would you mind if we got back to the actual topic, rather than dragging yet another conversation towards your slightly dodgy opinions?but how many of us with an experience greater than 1 poxy cottage
Why put the word "poxy" into the sentence ? Degrading the person rather than the opinion ?
Excuse my ego trip but this is the Walter Segal designed house that my wife and I self built in 1980 / 81
so my experience on designing heating and hot water systems in not limited to one Grade II listed thatched cottage. There is also a considerable amout of experience in the control and monitoring on industrial heating and hot water systems.
Plate heat exchangers - if specced correctly, will flex and break off the scale. Unless in a crazy hard water area in which case treatment should be in place anyway.
Having two water supplies will do nothing for the pressure. It will increase the flow rate.
I do agree with Bernard that combi's are a nightmare in these situations, although Vokera and Viessmann are making great strides in Turndown ratios. However they are a compromise. My default solution on this system (as described) would be a 180 litre unvented cylinder sitting under a 15kW or 18kW system boiler on hot water priority.
The 15mm copper should be changed for 22mm all the way to the cylinder location and the cold for the house drawn off the balanced outlet of the cylinder control group. If the upgraded pipe is not going to work, replace the cold water cistern with the aforementioned accumulator and then put an unvented cylinder in. Maintenance would add an hour per year, but an engineer with G3 unvented is hardly going to cost anymore than one with Gas Safe registration. Christ, it only takes 15 minutes to renew the certification when taken with the other exams.
Of course you can keep your cisterns in the loft and have noisy mechanical pumps.
