Please Help Potterton Netaheat 10/16 Spark Electrode ?
never done much work on a neta heat then raden? i know from previous dealings with these boilers just how dangerous they CAN be. :p :p
I've never even seen one
However, I stand by what I said before
answer the question, then point out the dangers
If they are that dangerous, why was there not a recall put out on them ?
just well publicised warnings about working on them,if you were competent about working on boilers you would know this.my advice was get a competent person to repair or replace.
Posted: Sun Jun 11, 2006 7:18 am Post Subject:
you need three things for a explosion,
fuel
air
and guess what the third is,yes you got it source of ignition and lo and behold the ht lead is not connected THAT IS THE SOURCE OF IGNITION.to the op leave the boiler alone and get a competent person to repair/replace, that is and should be the only advice given to the op.
Gasguru said:
Recalls are not good for business (the manufacturers that is) so they can take some finding but there have been plenty of them.
For starters the HSE press release and the service bulletin from Baxi
(found on an MOD release)
http://www.defence-estates.mod.uk/publications/health_and_safety/2000/hswn_00-16.pdf
and various investigations
http://www.hse.gov.uk/research/crr_pdf/2002/crr02406a.pdf
http://www.gas-news.co.uk/feature11c.pdf
http://www.hse.gov.uk/research/crr_pdf/2001/crr01319.pdf
Bookmarked, Ta
What, me work on a boiler ?
no thanks (unless it's mine)
