Wow, everyone has so much time on their hands to go digging up latin phraseologies, or they're sooo busy reading Part P from front to back, back to front, probably even upside and through a mirror just to be sure they haven't missed a comma somewhere in there - that they don't have any time to actually go out and do some work.
Tbh, if I was a DIYer and came across this site I'd be inclined to go elsewhere as there is little to be gained from the so called professionals on here who are supposed to be giving advice, but it appears all you 'sparkies' are interested in is quoting rule & reg and basically scaring the hell out of anyone who simply wants to have a go at doing his own electrics and/or plumbing, hell you'd probably even scare the hell out of someone who asked for advice on putting his bins out!
The OP asked a simple question and all he should have got in return was a constructive answer:
Are your new light fittings metal?
Yes? Then make sure the earth is connected at the ceiling rose (as a double check, pop the cover off the CU, assuming you've already flicked the main switch off as you've changed your light fitting (but be wary of the supply cables, you really don't want to be prodding anything in there that doesn't have a Volt meter on the other end of it) and have a peek at the L terminal connected to your lighting circuit and trace it back (if you can) to see if you can then find it's associated earth wire. Is that connected to the earth bar?
Yes it is? You're good to go. Put it all back together and have a nice relaxing life.
No? You'd be wise to investigate it further and if you feel it's beyond your limits get a sparky in.
Not that difficult to give constructive advice really is it, but hey, everyone's a keyboard warrior.
p.s. I've been in this business for 20 years and never had so much as a tingle from a livewire as I'm a careful sort of chappy. Never had anyone complain about my work either but that's probably down to my main rule that if I wouldn't do it in my own home, I wouldn't do it in yours either.
