22mm is through the heat exhanger - low flow rate in parallel with 28mm.
I still have recieved my accurate thermometer yet but I think there is an alternative solution as the boiler circulation loop is much more tunable. I'll set the heat exchanger to take enough heat out and then fine tune with the boiler but I may have to invest in a boiler protection valve to be sure.
