Possible wall damage? by drilling over sized hole on the wall for the new broadband cable
12 Jul 2011
Stirlingshire
Got new internet installed by an ISP. The engineer from the ISP came out, and put a line in through the house wall by drilling it.
After the installation is done, the internet seems working OK, but wife not happy about the way the wall was drilled. The drilled hole is way too large, and looks damaged. Please see the photo.
Can this be remedied by putting on some mortar or concrete cosmetically? Could this be addressed to the ISP for asking for repair on the wall? We are also unsure what kind of damage the large hole could have done to the stability of the brick on the wall.
It will not have caused structural damage, but it is unsightly.
For a good cosmetic repair, collect a cup full of matching stones (there will be a few lying near the wall)
When you have enough, carve out the silicone filler without scratching the cable, and expose the brickwork all round the crater.
Brush the broken brick with PVA adhesive mixed 50% with water and leave it to go tacky
Mix half a cup of sand and cement mortar
Press it hard into the crater. A small plastic filling knife will be suitable. Smooth it off flat and level
Press your stones halfway into the fresh mortar so they resemble the stones on the face of the brick
Great instruction for the cosmetic repair process, thanks.
We are wondering why such a large hole had to be drilled into the wall for such a thin wire to come in?
Those guys usually go in chewing gum and ready to kick ass with no time to spare for such trifling matters as changing a drill bit or wasting a moment in getting the job done before moving on. They could at least have put a cup washer around the cable to fill the gap, but JohnD's idea sounds just the job to fix it.
The hole has to be larger than the cable because the end connector has to pass through. But mine has a cover over it to neaten the appearance. Different colours are available but probably not for your brick colour.
