I always feel a good vibration from the pump, but as of today: NOTHING!
Scott McKenziePerhaps just the song about flowers in your hair ?
Obviously there is still a problem with boiler/system, its a shame that whoever changed your pump today didn't spend a few moments checking over some pretty basic stuff.
Few checks
1) Is the pump wired too and controlled by the boiler.
2) Is the pump overrun stat working correctly (unlikely fault from whats been described)
3) Does the system require & have a by-pass, is it set correctly.
4)Is main boiler stat within range.
5) System water quality.
Sounds a lot but all quick and simple to test/verify.
turn boiler stat down to 2
turn off hot water at prog/timer
turn on heating at prog/timer/stat
turn off all working rads
turn on (check both ends) of rad not working
leave it to do it's stuff, if not successful after 1 hr call a heating engineer
fingers crossed ay!
