Potterton Problems
3 Feb 2008
Kent
Potterton Suprima 60
Got up this morning - no central heating for hot water, so opened up the flap on the boiler and pressed the re-set button and it went to solid red.
When I adjusted the central heating timer so it was calling for heat, the boiler clicked, then an internal fan started (not the loud one you normally get when the boiler is running at full speed). At this point, the slow green light started flashing.
Eventually I got left with a solid green light, and a slow flashing red one.
We had the circuit board replaced a couple of years ago, and from memory, when the old one went bad, we had a red light that used to flash very quickly.
Any ideas what the problem could be?[/code][/b]
Is it easier to test the fan or the aps?
That way, I can narrow the fault down a bit?
