POTTERTON PROMAX COMBI 28 HE PLUS A minumum flow rate
15 Dec 2019
Anyone able to help with this one.
I need to fit a bypass valve to a POTTERTON PROMAX COMBI 28 HE PLUS A. The instructions for most of these bypass valves (Honeywell DU144 for example) seem to come with a chart where I have to refer to the pump speed and minimum flow rate for the boiler.
This boiler appears to have a fixed single speed pump, and nowhere in the installation or user manuals mentions minimum CH flow rates.
Of course, Potterton won't give me the information or assistance with the bypass setting not being a CH engineer. Anyone here knows how to obtain these figures?
Cheers
Mike
Boiler has automatic bypass, so as per @ianmcd any reason you need an additional one?
The supplier of an Evohome complete system with TRV's on all radiators recommends the external bypass, as did a quote for an install of an Evohome full TRV system.
I know that the boiler has an internal bypass, I can see it on the installation manual bypassing through the DHW Heater Exchanger.
Although not stated in the Potterton manual, other boiler manuals state not to rely on the internal bypass if all TRV's can be closed at the same time. It's a shame the Potterton manual isn't a bit more specific about the internal bypass performance.
Have come across a lot of the newer Pottertons in newer builds with external bypasses, probably because they all fit them at the top of the boiler and it's easily spotted.
Even with the internal BP though, it may not be able to allow enough heat dissipation/flow through the HEX under certain conditions where, according to more of the MI's I am reading recently, it shouldn't be considered as a substitute for an external one, when the system design asks for one.
