Potterton Suprima 60L keeps turning off with Green Flashing
LOL :D
Turn off the pump valves and remove the pump. You will have too catch a small amount of water. Fingers crossed the valves shut off! Connect it to a flying lead and see how it runs briefly.
Thanks, i'll let it all cool down first and whip it off.
So if I find that it is turning and the bearings seem ok, what do I do after that?
I'd check the impeller is all ok and not blocked or loose - ryou need to emove 4 allen key screws to check that - after closing is valves or removing as mentioned by petit_pablo
Also check coil resistance
I couldn't get it off because the valve upstream didn't close off the supply so I had a trickle of cold water.
