Open vented system. inc. hot water.
Hi, my problem started with a loss of heating when the boiler started then stopped and was kettling . So made a check of the F/ E make-up tank, level was correct, and ball Valve o/k.
When i bleed the first rad up stairs found no water. So first idea was to look for a blockage in the heating system.
Drained system at lowest point and also drained water at boiler - some muck as expected. Then also had to drained F/E as this did not drain. So yes its a blockage as in the past the system always drains with no problem.
With the F/E now empty by me tipping out the water i blocked off the vent over flow and connected the down side of the makeup water feed to the mains supply and gave the system a good flush.
Remade system and filled but not getting water to bleed and think that the blockage must still be there..Should a power flush be able to clear the flow / return circuits of sludge.
Will say at this point that a new boiler, hot water cylinder and pump was fitted in 2003 and think the pump has loosened some build-up /sludge
Anything more i should be thinking of or doing or missed?
Thanks.....Peter
Thanks.....Peter
