Hi all,
Hoping you can help. I finally erected a small shed next to my green house yesterday. The greenhouse has an electrician-installed shielded cable down our concrete fence, from our house which is directly connected to an RCD.
The greenhouse has a double socket, and I was thinking of just using a weatherproof extension cable or some 2.5mm cable with a 13 plug in the conservatory one end and a double socket the other installed in the shed.
Here are my questions:
1) Would you recommend an RCD plug or because the greenhouse electric is already on an RCD, we're good?
2) We're talking 2-3 metres max from the greenhouse to the shed and I'll be going above ground over the top. Recommend anything specific?
3) Whilst I can get an RCD plug, and the 2.5mm wiring to ensure weatherproofing, I'm worried that any double socket I get will have multiple poles and then I'd have to have run 2 wires.
As you can tell, I'm not an electrician, but my gut tells me something like this (if it were slightly longer) would be good.
https://amzn.to/3kwl7Ie
Any help appreciated.
