It would be quicker, if I knew how to.Perhaps it would be quicker if softus explained how to remove the remaining 10-20% of debris in a system.
I don't know, and I never implied that I know.I guess from his long winded and argumentitive approach he has either no intention or an inability to do so.
Does this mean that you consider removal of a mere 80% to be unacceptable?We will never be able to remove 100% in my opinion and to achieve 90% is acceptable.
A filter won't stop corrosion; only correct pipework, correct cistern water level (where applicable), and correct dosing will prevent corrosion.A magnaclean or similiar to help maintain the system afterwards is the best we can achieve.
Isn't a new pump a cheaper/quicker option then replacing corroded radiators and a blocked heat exchanger?If you put a y strainer on the return it has the ability to stop the carp getting into the boiler but it could affect the pump if the flow becomes too restricted.
[Are you able to explain what my profile (which isn't private) has to do with powerflushing and the functioning of a Magnaclean?
Well, your profile shows up as private when I try to look at it!!!
Have you become so paranoid about hiding your identity that you have listed it as private?
Tony
Hm. Rather selectively removed though, I notice.Moderator 10 said:Half a page of objectionable material deleted.
Maybe? Are you unsure about it?yes it is
maybe not to everyone.
So if a powerflush leaves behind 10-20% of the rust particles, and a Magnaclean doesn't attract them, then how do you get them out?
Here lol:where did this 20% figure come from lol.
So, what proportion of "crud" in a system will have affect how a system works?I think if there is a small amount of crud in a system...20% with the right dosage of inhibiter that '20%' wont effect how a system works
1stly the 80-90%, in all due respect to the quo tee, is an opinion, so the question has no standing in serious discussion on the subject.I assure you that I don't do sarcasm.
Do you have anything to offer on the question of getting rust particles out?
I don't know why you didn't say so at the outset, and save us all a lot of time.1stly the 80-90%, in all due respect to the quo tee, is an opinion, so the question has no standing in serious discussion on the subject.
You have the right to suggest whatever you like.I suggest you research the question before making your point on the subject.
It's a complete unknown then, other than the fact that Magnaclean won't remove the rust particles that aren't stuck to bits of Magnetite.For the record though & the benefit of our readers, the effect of the amount left in a system will depend on many factors,, as quoted by Tony being 1 factor !!
Au contraire - I was looking for information, and you completely failed to provide it, and you got all snotty.My previous quotes were valid and very useful but you decided you needed an ego boost but made a very wrong decision in choosing ME to do so!!
And there it is again - the personal comment.People like you who hide behind a keyboard and a screen and act condescending are just trouble making wimps IMHO.
And there's your veiled threat again. I guess that's what makes you big and tough.Would you be like this to someone face to face ? I doubt it unless you thought you could get away with it !!
