As usual it's up to pioneers like myself to do all the hard work for all of ya out there....(call me a hero if you must - feeling an aureola over my head right now - hawwww)...if I fail we all fail and then we'll need £300 more to buy the Boss BR800 (so, wish me good luck please)....
No, It's not that at all. This is like complaining that your toothbrush does not reheat your dinner. If you want to 'pioneer' yourself a new design, then 'so be it'.
As we have ascertained, the £300 model does what you need, but unfortunately, you have a cheaper model that uses a PC to do the processing in real time. You would be spending a 'lot' of time redesigning this, when you could be busking or getting a job to buy the £300 model in the first place.
Danechip....have your read my previous messages? The processing is done within the Edirol itself (why people don't get the fact first?) - it does everything when plugged via USB to a dumb Fostex MR8 (an old recorder which happen to have a usb host for a cd writer).
Your toothbrush example doesn't work...waaay over the top. The 9v socket is fairly common in other similar devices...
The problem with the £300 model is that it looks too good for the street - busking is a risky business...the Edirol looks cheap and cheerful and it's small - mind you, if I manage to get a neat solution (e.g. bypass the USB check and get direct to where the voltage matters) then, I might revamp this little fella and sell a modified version to buskers...
