ATAG use a combined PRV/Condensate arrangement utilising a tundish and 11/4waste directly to the boiler.
ATAG combine the PRV and condensate into one discharge pipe? A plastic pipe into a plastic trap? I know there is high temperature plastic pipe. Does this discharge, which will be boiling water and steam, have to be high temp plastic pipe?
Onetap mentioned a condensate vessel/pump that takes the condensate and PRV discharge. The location we have is that a non-condensing Vokera SE with remote PRV means no discharge or condensate pipe from the boiler position to a drain, which will be about 30 foot or more of pipe under a floor. The SE is easier to fit.
The ATAG having a combined condensate/PRV connection will mean no secondary PRV but a condensate pump (the high temp one Onetap mentioned? Which model is it?) and will need a plastic pipe back to a drain over 30 foot away.
The Intergas will need a remote PRV and condensate pump, or a high temp condensate pump as Onetap mentioned and 15mm or 22mm plastic pipe back to a drain.
Reservations are the temperature 15mm or 22mm plastic can take from high temp condensate pump to drain.
intergas added a prv as an afterthought for the UK, this is positioned on the flow pipe after the valve by a standard 22-1/2 tee arrangement.
Lee, what valve is this?
Lee, a good point about heating boilers being converted to sealed systems. The sealed system kits, AFIK, have a 3 bar PRV and can be located anywhere on the system, not specifically the boiler.
1) The easiest to fit is the Vokera SE with a secondary PRV
2) The ATAG (and can be the same for the Intergas) will need a high temp condensate pump and over 30 foot of plastic pipe back to a drain with no secondary PRV.
3) Next is the Intergas with i) a secondary PRV
and ii) a condensate pump with over 30 foot of plastic pipe back to a drain.
