Maybe you should get a ground worker in to price for foundation across the front and brickwork to plate height.I get the the multi trades issue like you've said, ideally need to find a smaller outfit I guess
I'd like to know where you can find these young men - except in front of a computer screen?There are around 2 million young men in the UK who will work for a few quid a day....
modern slavery has made a come back but the irony is that its now a bigger business than it was in the "olden days". Find a car wash,,find the slaves...simplesI'd like to know where you can find these young men - except in front of a computer screen?
I'd we could find such then my wife would be happier, I'd be bored and my mate would have a full time work mate.
Definitely well worth a dig to find out, shouldn't take more than a couple of hours. If so that will reduce the price, if not then the £6.5k is probably fair.Are you sure the house foundation is not already there?
The returns are not adequate in their present size and need increasing to satisfy B' reg's. It would be a foolish risk to attempt to remove more masonry than is necessary.I can't work out the corner detail from your drawing
Make sure that you do as much work inside the conversion as you dare, before bricking up that opening. Get all the large stuff carried in and fitted where you can. That includes plumbing (heating) and electrics. They can leave any cables hanging or pipe tails for now, where the opening is concerned.Thanks all. Yes just the garage door removal and brick up. No internal works for the rest of the conversion.
Yes, but with this bit...It looks like the drawing shows the old corner remaining,
Lol, I have yet to find a machine that I can wedge into a garage door opening and successfully dig. You may be able to pull a bit from the side but it would be messy and risky. There will likely be services, so hand dig for us every time on that little job.-digger for foundation dig
If the foundations concrete is a continuation of the existing footings, they will accept it. It's fairly common on modern houses for the digger operator to remove the whole trench (easier), where the garage door opening is concerned.test holes to see what existing foundation is building control will accept drill holes but they usually wont accept 600mm of a foundation that your proposing
Mate done exactly the same and building control wanted at least a metre
