M
martineire
I'm currently goin to upgrade my heating system with condensing boiler/heating controls but I'm having a problem in how I'm goin to go about altering pipework for the zones. I'm living in a 2 story 3 bedroom semi-detached house. I've currently got an open vented system the boiler is a wall mounted baxi solo 2 which is downstairs and the cylinder is upstairs. The boilers flow and return tees off downstairs for the downstairs rads and for upstairs rads and cylinder but the problem is where the flow and return comes up in the hot press for the cylinder branches have already being taken off to rads before they get to cylinder (no primary flow and return from boiler directly to cylinder.) Any ideas on what's the best way in goin about altering the pipework so I can put in my 3 zones? I can put my motorised valve for my downstairs rads where they flow tees off downstairs for downstairs rads and I can put my motorised valve for my hot water on the flow at the cylinder and also the bypass there and seal the system there but the problem is how am I goin to zone my upstairs rads considering the flow and return tees of to a couple of rads before getting to the cylinder Is my only option but to run the flow and return from boiler directly to the cylinder without any tees off to rads then link in with the existing flow and return at the cylinder goin to rads. It's just that, that will require sections of the ceiling being cut out downstairs from where the boilers flow and return run to rads/cylinder in ceiling so I can alter all that pipework, it's just that it's starting to get very messy then but I see no other way around it.
Is there any experienced plumbers that can come up with an alternative solution thanks?
