Hi All
Sorry, but this goes on a bit. There is a point to it...sort of.
For a good few months now we’ve had up to 10 small appliances plugged into a single socket in our lounge, using an extension lead plugged into another extension lead. Not ideal, I know, but we’re woefully short of sockets in this room, and yes, I do intend to do something about it. However up till now, no problems, no outage, no overheating sockets or plugs.
Today I purchased a socket convertor and changed that single socket to a double. I plugged one extension, which was powering three appliances—a router, a powerline adaptor and an alarm panel—into one side of the new socket, and the other, which was supplying four appliances—TV, sound bar, TV catch up box, and another powerline adaptor –into the other socket.
About two hours after all this stuff was connected, the RCD for that circuit tripped. I took the socket off the wall and checked whether any cables were trapped or not fully connected to terminals—all fine and dandy. Put it all back together and after about five minutes it tripped again.
About 18 inches from this new double socket, horizontally, there's a switch fitted by the previous occupiers of this house, the original purpose of which is unknown to me. To make more room in the new box I disconnected and terminated the cables in the double socket supplying that spur, put the convertor back on the wall and tried again. Once again, after a couple of minutes it tripped (it later occurred to me that I could have left the existing single socket in place and put a new one on the spur, but by that time I’d cut the cables).
I then connected the extension with three appliances plugged in and removed the one with four, and hey presto—no tripping. This indicated to me that the second extension lead was at fault, so I went out and bought a new one, and so far so good.
The above epic prompts me to ask a couple of questions: firstly, why did my extension lead (if it was this lead which is at fault, and right now it seems that way) choose this moment to give up the ghost when it was fine for so long whilst plugged into an ancient single socket? Secondly, are the new socket convertors somehow more sensitive, for want of a better word, than the old fittings?
