Kit: three monthly old Honeywell Sundial RF2 pack 2 controlling a Vaillant 428 boiler for central heating and hot water stored in cylinder
I hope this is not too dumb a question! I would have assumed that, when a central heating ON program is current, if the set point of the wireless room stat is less than the current temperature (as shown on the wireless room stat), the boiler would be asked to (continue to) fire; when the set point is reached, the boiler should be shut off.
I believe the Honeywell (if not most/all other) programmer fires the boiler when the temperature = the set point, so the room maintains the set point (although that's fairly annoying as it can push the room temperature up more than we'd wish it - though I know this can be tweaked with the boiler cycle rate/hr setting on the Honeywell).
However, what is very odd to me is, when the temperature is GREATER than the set point, the boiler/CH is still firing and the rad's are getting warm!
Am I correct in thinking, given I am aware of the Honeywell boiler cycle rate setting and how this (should) work, and the ability to adjust some Vaillant timings, that the stat or programmer is faulty?
