Programming advice for Texecom Premier elite 24
Enter engineer code
Display says need user to enable access
Enter master code
Do you want to enable engineer
Press yes
Should now be in engineer mode
Enter engineer code
Enter master code
Press yes
You legend thank you. Do I need to confirm the devices through the keypad then as I can’t see anything in Wintex to do this & do I need to do anything with the keypad in Wintex?
Confirm devices if needed would normally come on the keyp[ad screen when you enter engineering mode.
However engineers code/(9) Engineer utilities/(5) confirmed devices
Note:- you have to re enable the engineer as set out above every day (access reset at midnight).
Thank you, it was a long night o_O I have one system alert left which I think is because I have the panel lid off, I'm going to do a walk test today but when it comes to users do I just use the master and change the keypad code for us or do I leave that alone and create a new user for us?
It is always recommended that you Change user and engineer codes away from default values.
Master code is user 1 you can change this to what ever code you want.
So there's only going to be me and my partner as a user so shall I just use the master set up and just change the code for us instead of adding another user if that makes sense?
Ah I get you. Think we'll just use the master set up for us then with a new code and then change the engineers code if that's right?
the default codes are 1234 engineer and 5678 mater user, you should change both as they are relatively well known and keeping the default values compromises your security system
All sorted, default codes changed and all tested fine. Just the texecom connect to attend with at some point o_O Thanks for everyone's help, very much appreciated
Some struggle especially if its on a wifi connection, but the instructions are right but you will have to download them as they don't go out with the products anymore
No doubt I'll struggle then :)
Just out of interest, can a wireless door contact be used with this wired system?
