Hi everyone,
I have a Pulsacoil 2000 thermal store which is connected to an off-peak timer with a boost button. The off-peak timer currently runs from around 2:30am to 8:30am and the boost is currently set to be on from 6pm to 7pm. Please note that I have no control over when the off-peak timer runs - this is controlled by the electricity tariff that I am on.
The problem is that there is never enough hot water. In the morning, the water runs out before the second shower (even while the off-peak timer is still running). In the evening, there is not even enough for one bath.
As I understand it a thermal store will gradually lose heat over time and the water will become cold. However, I would not expect the water to go cold so ssoon after the timer has been running. Also, the water goes from piping hot to stone cold in the space of a few seconds which doesn't sound like a gradual loss of heat to me!
I found another website which suggested a possible solution (making sure that the expansion tank is full) but unfortunately it didn't solve the problem.
Any help that you can provide will be gratefully received as it is really frustrating not having enough water.
Maany thanks,
Nick
Maany thanks,
Nick
