Hi guys. I have a Potterton Prima F50 and i realized that after the call for ch or hw goes off, the pump runs for ever...and i mean it! The pump itself Grundfos 15-50, is scorching hot and so are the primary flow pipe, the by-pass in the airing cupboard fitted with a gate valve and the return pipe back to the boiler, despite not having been a demand for ch or hw for many hours and the boiler has not fired up. Last night, to try and stop the pump running, i called just for a few minutes,for ch which was completely cold and shut off the bi pass valve. Since the system was completely cold, the return pipe went cold and at that moment i switched off the ch and reopened the by pass valve and the pump switched itself off. My question is
1) is the pump overrun timed or connected with the boiler stat so that the pump keeps running until the boiler stat drops under a set temp. I do not know whether that was a coincidence but as i said as the return pipe went cold yesterday and i switched the ch off the pump stopped running .
2)what is causing the flow pipe, by pass, and return pipe to the boiler getting so hot and not cooling down even though there has not been a call for heating and the boiler has remained off for long time? The pump seems to work ok and there does not seem to be any big problem with sludge as whenever there is a call for ch the rads upstairs and downstairs get hot within reasonable amount of time. Thank you for your time.
