I think the spark that rewired my house bodged my instructions.
I asked for a switch to connect a pond pump.
What he has done is spurred a double socket from the ring main (I know this cause i could only see one wire going into it before plastering).
From this he has wired a single socket (so in effect a spur from a spur).
He knew this point was to be used to connect a pond pump.
Is it possible to install a 3amp fuse in what looks like a 13amp single socket? Or should he have used a FCU?
The two spurs run horizontally through a wall which is L shaped.
i don't want this guy back so could I swap the single socket (if this does not have a 3amp fuse in) for an FCU?
