Pyronix enforcer
You have two sensors on the landing? One of them is programmed off your night set (B) and one of them is on both full set (A) and night set
I have identified 06 is the family kitchen ( not Landing ) and is set AB intruder
it’s not clear what exit modes you have selected for A and B. You have listed the options that are available
I am not sure what you are asking. I altered the description for 06 and now when I set ALL the cp has a contact tone
OK I see now both A and B are set to (2) Timed final
What is the B exit time set to? B exit mode should be timed. And b exit volume, - would reccomend to set this to 1, (silent woth confirmation chime) or 0 (silent with no confirmation chime)
If all that is ok then yes you probably need to reprogram your fob
I have set it from cp, selecting b. It sets and when I am present at the hall pir it doesn't see me
You set area b from the keypad and the hall pir doesnt pick you up?
Set B on the control panel, wait for it to beep/ set. Then walk down the stairs to the pir. It should flash,pick me up and start beeping, it does norhing
