Hi there,
The back wall on our out building is leaning at an angle of about 4 degrees. The wall is free standing, very old (200-300 years) about 2.5m long, 1.5m high and probably with no/little foundation. It has been moving for over 100 years (talking with neighbours). It is not tied into the walls on either side and doing so isn't really possible.
The pitched roof is off at the moment just leaving the frame there. This just sits on the wall.
You can see where attempts have been made in the bast to brace it to the side walls, but this has just pulled more bricks away at the sides.
The problem is due to what is behind the wall we can't rebuild it. We can get to the back but only have about a 20cm space.
The floor inside is solid concrete.
We were thinking of a way of bracing the back wall to vertical beams running parallel to it inside. So kinda making a new wall structure inside and bracing the back wall to that. Tying the vertical beams to the concrete floor and the wood ceiling structure and then drilling through the back wall and vertical beam and putting a brace through it.
Extra support to the roof will also be added.
Can anyone think of any reasons why this may not work, better ways of doing it or any commercial products that could help?
Thanks,
Sam
Thanks,
Sam
