Just bought a 12V (12A) battery charger for the caravan battery. Hooked it up this morning and left it for 3 hours > came back to it and there doesn't appear to be any charge in the battery.
I've tested it with a miltimeter (while both connected to and disconnected from the battery) and the reading's coming back as around 2.5 volts - I assume it's borked and should be spitting out around 13-14V?
It's not a trickle charger BTW. Fuse is ok and the "charging" LED is lit, but nowt much in the way of power.
Just want to check before I take it back so I don't look like a divvy... Cheers
