- Joined
- 27 Jan 2008
- Messages
- 27,500
- Reaction score
- 3,325
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
We do not use the auto start from phone, although in the drive there would be no problem. I have noted ambulances where engine is left running but you can't drive car away, to keep things like blue lights running without battery going flat, so clearly there are circumstances where it is allowed, but I know while waiting for my wife while she was in hospital it was extremely annoying when some one parks next to you with engine running, one assumes so the AC works. So I would not do it myself.
Unless battery has enough charge the stop/start is inhibited, so in real terms rarely works.
As to @Harry Bloomfield method yes I would consider using a timer, but then the Lidi charger was under £15 can't see the point, I just move charger from battery to battery.
What I was surprised at was how long it takes to fully charge a battery, the sulphur goes hard, and with a heavy sulphated battery it can sit it seems doing nothing for a fortnight then as if a switch flicked start to charge, I suspect the Kia battery getting on a bit now, but the rest, even on 0.1 amp charge rate raise above 12.8 volt when fully charged, and that is what I look for, so once at 0.1 amp and showing 13 volt or more I assume fully charged, but looking at a few days, not hours.
I thought the Jazz was on original battery, but when it failed last year saw Halfords written on it so clearly not the original, but battery life seems can vary 2 to 15 years, even when same owner, so more luck than good care. But the keeping of a battery at 80% to my mind is OK when car used 5 out of every 7 days, and the computer every so often fully recharges it, but when the car is left for a month without being used, then the battery does need topping up before being left and likely every 6 weeks after.
