Quinetic - How to connect?
In your opinion, is Quinetic (and the likes) the future of rewiring / adding additional switches?
I think that's probably two questions.
Such devices certainly can offer a very convenient, and potentially minimally (or non-) disruptive, way of adding switches to an existing installation.
On the other hand, if one is wiring a house 'from scratch', either in a new-build or a 'complete re-wire', then such devices represent a very expensive way of switching. I also suspect/presume that, being electronic devices, they are probably more likely to 'go wrong' than are mechanical switches - with the risk of encountering such a problem presumably increasing if one has 'a house full of them'.
Kind Regards, John
Kind Regards, John
Thanks for the comment John
Perhaps as time goes on and with rising popularity, prices may drop?
And that's an excellent shout, regarding the potential failing of these Quinetic devices.
Amongst all the praise for this device i have seen a comment from a user who claims that their receiver failed.
I guess that this could be incredibly inconvenient if the receiver was located under the floorboards
Thanks for the comment John ... Perhaps as time goes on and with rising popularity, prices may drop?
Indeed, at least in 'real terms' - but I doubt they'll ever be anything like as cheap as mechanical switches..
And that's an excellent shout, regarding the potential failing of these Quinetic devices. ... Amongst all the praise for this device i have seen a comment from a user who claims that their receiver failed. ... I guess that this could be incredibly inconvenient if the receiver was located under the floorboards
Quite so - and, in contrast, mechanical switches are eminently 'accessible', should they ever need to be replaced.
Kind Regards, John
If I was having such devices fitted I would also want them to be smart Wi-Fi controlled. Not that I’m a fan of that thing, but it would make sense
Very handy technology should y
Yes, then you could turn your bedroom lights on from your pool side chair in Bali. Why would that be Needed?
Steady on there Doc :D
WiFi compatibility could act as a security feature
While out in Bali, one could switch on the lights to give the impression that someone is home
I did say I wasn’t that keen on tech :D
1 you could turn off all lights when leaving house. That would have saved me 40p in the last 5 years :rolleyes:
2 turning lights on without getting out of chair. That would be useful.
I guess you won’t be getting one of these
... WiFi compatibility could act as a security feature ...
True, but I imagine some might suggest that it might also act as a security vulnerability!
One could, but for decades we've had ways of achieving much the same without having to utilise 'remote control'.
Unlike some, I have no problem with people who, for whatever reason, like to have a home which can be 'controlled from their smartphone', although I personally see few real advantages. I've already voiced my greatest 'doubt', which relates to the fact that (maybe because I'm old!) having a house depending for its functioning on lots of 'new-fangled electronics' feels much less reliable to me than is the case with good old-fashioned switches (which I can always replace in a minute or three if I ever have to). However, as they say, "everyone to their own".
Kind Regards, John
That sort of thing always reminds me is Home Alone. The burglars knew nobody was in, because the automatic lights always turned on and off at the same time every night.
It does - although that particular problem is easily avoidable, since means of random switching have been around for decades.
Kind regards, John
