I think you are worsening your confusion, by starting two threads on the same issue.
All you need to ensure, is that the roof is completely flat, though not side to side level. You can do that by eye - placing the rafter at the 700mm wide end first, then by sight, setting up and marking the rear one, to perfectly match the angle. After marking it, you cut it.
All you do then, is insert the rest of the joists, in exactly the same manner.
Keep in mind - the angle that the joist ends are cut, where they meet the wall plate, will all be exactly the same.
'If yes, how do I match the two joists without a digital angle finder?'
Use your eyes, once the longer one is in place, the shorter one at the rear, can be sighted using your eyes, to get it to the same angle, always providing the two timbers are parallel. .
