- Joined
- 27 Jan 2008
- Messages
- 25,827
- Reaction score
- 3,063
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The question is will two RCD's be safer than one assuming both are in working order.
Answer must be no as the current differential between line and neutral will be the same or less at the plug as it is at the consumer unit so with a 30ma unit in both places the consumer unit device is likely to act first as likely there are some leakage paths between the consumer unit and the socket which will likely make the consumer unit one more sensitive.
With both 2 core and 3 core cable cutting the cable with a lawn mower or hedge trimmer is so quick it is unlikely the RCD will trip. It only really helps when some one picks up the cable and tries to repair it without first turning off the supply. As to if having a resistive path through the ground or a near non resistive path through a earth wire goes both are likely to trip the RCD but through the earth wire is likely to give a far higher current until it does trip. So I would say keep with the two core cable.
As to using a 10ma RCD on the plug, yes some caravan suppliers do stock them, but time will be the same so since under fault conditions unlikely less than 30ma will flow there is no point as likely both will trip in nearly the same time. In any case less than 40ms.
So answer is simple no point in doubling up on RCD's
Which leaves the question why when any caravan site has a 30ma RCD on the supply should there also be one within the caravan? Sorry have no answer. Likely a TT supply with rod at the supply post so just can't see any point in fitting two RCD's unless the earth is not imported as would often be the case with boats. But never seen an isolation transformer or a diode in the earth wire with a caravan that only happens with boats.
