Have recently had an electric shower fitted and a fault showed up just as the electrician was admitted to hospital. Please can someone tell me if they think it is the shower or the wiring to it that is responsible. Supply has been split between the consumer unit and separated RCD unit for the shower.
The RCD trips when you push the on off button on the shower. If the shower is not switched on then the power light on the shower unit is on & RCD remains connected.
Electrician believes it may be a fault somewhere else in the house but he may not be thinking straight at the moment.
I need to know as if it is the shower I need to return it.
