have you tried as i suggested??
Johnny
Any other circuits on the load side of the RCD?
Isolator switch could either be a pull cord switch (in the bathroom) or a wall mounted switch outside.... a common fault is the neutral burning out,, that's what I was meaning that you should check!
Just read the last post properly - job done. I hope you don't mind the other info if it helps!
No it doesn't.Part 'P' building regs specify 10mm cable.
Part P is not a qualification.A qualified electrician (and these days he/she MUST be a Part 'P' qualified)
Indeed.God help us all!
You don't.If Part P isn't a qualification why do you have to pass an exam to get it?
Get what?How else would you get it?
No they don't.Plumbers have also to pass an exam called 'Part P Defined Scope' if they wish to wire boilers, showers etc.
You can't.
Part P is a part of the Building Regulations.
A part of the Building Regulations?
They can't.
Misunderstood is right.Come on BAS; you know what he means, we know it is a regulation, but to be able to self certify, one has to pass an assessment to join one of the organisations that run competent person schemes. This is commonly understood or misunderstood to be a part p qualification and there is a defined scope scheme for kitchen fitters and plumbers.
