- Joined
- 22 Aug 2016
- Messages
- 16
- Reaction score
- 0
- Country
Hi Everyone
I have a puzzler.
I have a split rcd cu. The left hand side is fine which powers everything other than lighting and power (including the kitchen ring) The right hand side has 6 mcb's, basement lighting, basement power, downstairs lighting, downstairs power, upstairs lighting, upstairs power. The right side rcd trips randomly. tonight I have been sitting in one room upstairs on the computer and the rcd has tripped 8 times. I havent moved or done anything to make it trip. The only thing plugged in is the laptop charger. Everything else is plugged in from the kitchen ring which has no problems. Each time, I switch all mcbs off, switch rcd on then 1 at a time switch mcbs back on. the first time, when I switched the downstairs power mcb on, it tripped the rcd again so I removed the neutral wires, and left the mcb off but switched on all the others and it was fine. less than an hour later and it trips again. This time I check and the basement lighting mcb trips the rcd when I switch it on so I remove the neutrals and leave off the mcb and try again and all works fine. I continued this until there was only one circuit connected. When it tripped again, I took out the last 2 neutrals, tested continuity on all neutrals and all was fine so I put them all back in the right places. I went through the whole cu checking all the screws were tight and switched it all back on. All the circuits worked fine for about 90 minutes and then it tripped again. This has been happening for the last few days. Today, it was fine for about 4 hours then tripped twice in 30 minutes then fine for a few hours. There doesnt seem to be a pattern.
Can anyone point me at a place to start?
Any advice would be very much appreciated
I have a puzzler.
