Nor you yours.In your opinion, for which you will not (because you cannot) provide a citation to anything which supports your claim.
- The law requires reasonable provision for safety etc. No "citation" needed - it says so in black and white.
- Whilst compliance with BS 7671 is not formally required, that is the British Standard which relates to electrical installations, and to deliberately refuse to implement a requirement of it which is intimately related to personal safety but instead to do something which the standard no longer regards as safe enough to be continued to be done is not reasonable. No "citation" needed - it is so blindingly obvious that unless a genuine lack of intellect means that someone simply cannot understand then if they deny it it can only be because they are deliberately refusing to accept it.
Yup - not using 30mA protection it is no longer considered safe enough for the practice to be allowed to be continued.As far as I can tell, you are trying to use BS7671 to support your argument by referring to its 30mA RCD regulation and insisting that not providing such is therefore "not reasonably safe" because the committee has specified it for new installations.
I'll make you an offer:Yet at the same time you choose to ignore the guidance for inspections within BS7671 from the same committee which does not indicate that absence of such protection should warrant a code suggesting either immediate or potential danger.
I will stop telling you that there is a difference between assessing what is already installed and installing something new shortly after you stop pretending that there isn't.
From now until one of us dies or until you leave, I will challenge you every single time you seek to grievously mislead people by telling them things like you did above.I do not intend to rehash that argument here, but summarize it only for reference in this particular topic.
If you don,t intend the argument to be rehashed, stop.
