The term "RCD" is not used to describe a device which provides overcurrent protection.
The fact that some residual current devices do provide it does not make it any more correct to say that "RCDs provide overcurrent protection" than it does to say "motorised vehicles provide comfortable seating for 50 adults" just because some do.
It is misleading and possibly unsafe to tell people that RCDs provide overcurrent protection when some don't, particularly when they are simply described as "RCD"s.
This says "RCD" on it:
It does not provide overcurrent protection.
An RCBO is a circuit breaker - would it therefore not be idiotic to say that circuit breakers provide residual current protection?
Given that this is a DIY forum, and we recently had a DIYer here who thought that a switch provided overcurrent protection because it had 100A written on it, maybe the idiots are the ones saying that RCDs provide overcurrent protection.
No-one said RCDs provide overcurrent protection. They only said that certain types (RCBOs) do, which would be obvious to anyone who knows what RCBO stands for.
You are the one who says that incorrect usage of language should be challenged (e.g. electrocution) and yet here you are trying to defend abuse of the term RCD.
It is a generic term. Therefore I am challenging you on your misuse of it. An RCBO is an RCD which has integral overcurrent protection. That fact is not disputable.
RCD is just a generic term
Even though the device in the MK piccy says RCD on it, the correct terminology for it is an RCCB - which is a form of RCD.
It is like looking in the regs at the term RCD and saying we must use a device with RCD printed on it, infact we can use RCBOs, RCCBs, SRCDs, current operated ELCBs etc.
No. I said that certain types (namely RCBOs) provide overcurrent protection. So it's not correct to say that no RCD provides overcurrent protection, although I have made clear on every occasion that it is not the RCD function providing it.
You're usually pedantic (don't worry - I like that) but you can't change definitions when it suits you. I can be more pedantic than anyone.
Just, as I said, pushing back against the idea which seemed to be being promulgated which was that it is not wrong to say that residual current devices provide overcurrent protection.
