So... can it be a wall switch?
Two pull switches next to each other never look good.
A holesaw on the coving would work, as long as the pilot is long enough.
Be aware that occasionally cables can be routed behind coving.
Do you need separate switches for the light and the fan or could they come on together?
Could you move the switch(es) further in to the room so the strings aren’t in the path of the door?
Put the switch in the wall, in the bathroom.
No.A waterproof switch?
It isn't.A humidity sensing fan might be a way around this.
I thought electricians were loathe to put wall switches in bathrooms despite the permission in the regs.
They require constant adjustment and rarely work as intended.I don't follow you re the humidistat fan,
You shouldn't recess surface mount switches. You'll only make life awkward for the next person and it will probably need to be smashed out with a hammer. And have observations about it during periodic inspection.
You're the one talking nonsense. I'm highly qualified. You are not.Nonsense. Both the switch plate and cover remain readily accessible because they're accessed from the face/below. Yes, the wall side/inner side of the mount is a little below the surface of the coving but so what? Nothing prevents you accessing or indeed removing any part of the switch, inspecting it or replacing it in the future. Don't see where the need to smash anything with a hammer comes into it, an invention on your part I think.
Not sure what 'periodic inspections' you are talking about, it's my home, nobody is coming round to inspect it unless I pay them to do it! If I or an electrician want to have a look at the switch we would simply unscrew it and inspect it because, well, see above.
