You're the one talking nonsense. I'm highly qualified. You are not.
Please explain what would need to be smashed with a hammer and who is coming to perform these inspections.
There are enough different size holesaws on the market to get a perfect or near perfect fit for the pull switch.
There shouldn't be any need to fill all round it.
A pull switch with two fixing screws on the front is what you want, not one with a cover that you turn with your hand to loosen.
If you like, you could fit a white besa box between the ceiling and the pull switch, to bring the pull switch lower.
The question now is are you highly qualified enough for that pompous git to listen to?
The real question is why you are such a know-it-all ass...Yes and funnily enough I have two screw fixing pull switches. The question now is are you highly qualified enough for that pompous git to listen to?
Still can't answer my questions despite your high qualifications? it's funny that because you live on the border and need two sets of qualifications it makes you think you're twice as good as any other electrician...The real question is why you are such a know-it-all ass...
Me neither and I'm not sure @Risteard is coming back to enlighten us the need for smashing things with hammers or who is doing the periodic inspections in private housing in the UK?I've recessed pull switches before. A round dry lining box works well as a back box.
You have Schneider (formerly GET) brand switches which have BESA standard fixing centres and will screw straight into the box.
Not sure why you would need a hammer for this?
Now, so I can decide if it's worth the hassle or not, if I did decide to recess it how would I cut the coving, will a hole saw work or a padsaw?
, and other activities probably not at all.
A PIR in the fan, gets around that.
Do you mean the fan is activated only by motion or motion and humidity are required via PIR and humidistat?
My ideal would for it to come on automatically with the shower and have a five minute manual switch for smelly evacuations.
