Well I now have a premier 24 installed connected to the original detectors. I have replaced the keypad to a Premier LCD and fitted Premier keypad in the shed. My 8 core alarm cable is run in unistrut from the house to the shed. There is a door contact on the shed door and a texecom dual tech detector in the shed wired to the keypads zones.
I powered up like it said black battery lead, red battery lead, press and hold factory default button, press battery kick start button, green heartbeat light illuminated,let go of factory default button, system went into alarm and i entered default eng 1,2,3,4.
Confirm devices menu appeared , it was scrolling through the devices I had so press yes and yes again.
At this point I don't remember the display changing but as I didn't know what I was looking for I climbed back into the loft to get the computer to talk to the panel via com port.
I played around with wintex and think I sussed it out and then sent my settings to the panel.
I can enter my new user passcode and it accepts it but keeps coming back to confirm devices with all the zones displaying tamper faults, keypads tamper faults, all zones showing active. I press yes and yes again but it keeps coming up with system alerts and phone alarm com.
I have wired up all of my detectors across the alarm contacts and then back to the zone I want in the panel and no resistors( I now know this is bad practice) and the tamper contacts back to the aux/fault contacts in the panel. The detectors in the house were wired like this on the veritas system I have just removed so haven't altered in the field just disconnected from veritas panel and reconnected in new premier panel. In wintex I have said the zones are doublepole end of line.
I can't get the keypad to do anything, it's as if it won't even let me confirm devices. Also when I now put it 1,2,3,4 it says I need to put in a valid user, I didn't alter the eng code(or don't think I did). The user code that it does accept has all the parameters set so I can access all areas.
Any clues to what I have done wrong?
Many thanks in advance,
Si
